P0440 Problem
2001 Silverado 1/2 ton 5.3L 135k miles
I was getting P0440 along with P0442 and P0446. I replaced the vent valve solenoid in the rear and the P0442 and P0446 went away, but I am still getting the the P0440. It also idle's kinda rough. I did replace the gas cap with no change.
Any ideas?
Thanks
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,016 Guests (See full list)
