2014+ heated leather steering wheel
Leather steering wheel with red stitching from sierra slt all terrain, buttons and metal brackets are from a denali. All buttons work as well as heated wheel.
$100 shipped.
20150607 213706
20150607 213638
  • 5 weeks later...
It should just be plug and play if you have any type of steering wheel controls. Otherwise you may need a different clock spring.
Oh well dam thats far and thats alot of work.
  • 1 month later...
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
