Fuse issue
So this past weekend my gauges stopped working. The fuse looked fine, but pulling it out and putting it back in again seemed to fix the problem.
Then yesterday I couldn't get the truck to start. I pulled the fuel pump relay out, rubbed the contacts with my fingers, and put it back in again. I did the same to the fuel pump fuse. That also seemed to fix the problem and the truck started up just fine.
So what is going on here?
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,201 Guests (See full list)
