clean heads while replacing knock sensors
I'm replacing my knock sensors (2001 silverado 5.3), and the intake ports on my heads are filthy (150k miles). I would like to clean them up a bit before putting the intake manifold back on, but not so much that I want to remove the heads or cause new problems by introducing crud into the cylinders or around the valves.
What is the best approach for doing some cleaning in this scenario?
I can stuff some towels in the ports and clean up the very top of the ports...but that doesn't allow me to get very much. Is there a better way?
Vacuum cleaner and some rags. Vacuum before and after you pull the intake, then stuff the ports with rags. Keep the vacuum running while you clean.
is there any way I can turn the engine "by hand" to close any valves that are open (before I clean them) as an added measure?
I've been able to hook a 1/2 inch drive ratchet with a socket on the crank and turn it over...shouldn't be too hard since there won't be any compression.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
