2014 shifter not moving out of park
Occasionally after starting the truck and getting ready to move, the shifter lever will stop at reverse and not move. Moving the tilt well seems to allow the shifter to work normally. Had anyone else seen this issue?
This is new one to me. Have you tried turning the steering wheel back and forth? Sounds like a warranty issue.
Sounds like you may be trying to use the wheel in a position that isn't locked in. Or the wheel lock itself is not functioning correctly thus you are limited in what gears you can select.
Sent from my SM-G900P using Tapatalk
Thx. I am going to start keeping a log and the remedy. It doesn't happen often enough yet to waste a trip to the dealer to get cannot find anything wrong.
You show them what's wrong , ya don't just hope for the best while sitting on your but in the lounge !!!!!!
Always show someone and make sure THAT guys name is ON THE WORK ORDER so the tech can go to him /her
Not hard
    bellssn690
    bellssn690
  • Who's Online   3 Members, 1 Anonymous, 886 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
