Calculation
varmint2506
The new gear ratio calculation doesn't seem right to me I think the new  and old tire blocks are backwards. Try it you willsee what I mean.
Yep!
That's really strange. I ran the calc's. the other day and it worked right. The tire size is backwards now. :werd:
    zibzer2
    zibzer2
  • Who's Online   3 Members, 1 Anonymous, 799 Guests (See full list)
