Reprogramming w/Allison Tranny
Does anyone know how you go about re-programming the computer for bigger tires.  Hypertech doesn't do it with the Allison, and I can't seem to find anything that does.  I have seen 2500HD, lifted and with bigger tires, so they gotta do it somewhere.  Any help would be great
Thanks
What engine?
Hypertech released their Duramax PPIII unit recently, and that allows for speedo calibration with up to a 38" tire. Don't know how  well the program runs, but from the dyno sheets it is a bit low on torque.
The other option is the Superlift  Tru Speed, http://www.superlift.com/speedcal.asp
I've got the 8.1 and the Allison transmission.  I'm not worried so much about performance as I am with having my speedo and odometer correct.
TMF
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
