Flag mounting
i made a small 2x10 "C" shaped mount. Then screwed a piece of pvc to that and used tighten it to the front drivers side tie down. Works really nice, doesn't take up much space and leaves me a nice cubby to put my air hose in when i head to the beach. Will post pictures later
    Gkistler
    Gkistler
  • Who's Online   1 Member, 0 Anonymous, 881 Guests (See full list)
