Odd MyLink Stereo issue...
HBKidJr
I've had my '14 for a few months now, and I love it...other than the clunking seat, I've really had no issues with it. About a week ago, though, a song I enjoy alot came on (bluetooth streaming from my phone) and I noticed the opening guitar solo wasn't playing. I thought maybe it could be the stream, so I plugged it in and attempted a USB connection. Same issue. So I thought maybe I'd just never noticed before and I had a super low quality version of the song, so I pulled up YouTube and played it from there. Same issue. The entire high toned guitar solo is missing. I thought maybe it was just my phone then. I tried my wife's phone. Same issue. Tried a few more songs and it just sounds as though I'm not getting any high pitched notes, only the lower range. So I went to the dealer and tested it out on a brand new truck and it worked without any issue at all. I've adjusted all the tone settings and even factory reset my stereo with no solution. I've got an appointment with my dealership for next week, but I thought I'd check in here to see if you guys had any ideas or the same experiences with yours. If it matters any, I get alot of "skipping" noises whenever I use the pause feature on live radio. Probably something separate though.
Thanks!
