RPM falls under 400 when braking
HI there,
The other day I was driving my car around, I came to a road bump and had to brake hard from a speed of almost 60KM/H and let go of the brake at a speed of almost 20KM/H. the engine simply went off.
it happens regularly overtime I brake but the RPM falls to around 300RPM causing the car to jerk, however everything returns to normal once I apply throttle.
Dealer said this might be because of a dirty throttle body the cleaned it but the problem persists.
A couple of tuned sierras don't have the issue because the RPM is raised to 800RPM while idling and when the gear is set to D.
please help with your feedback.
thank you
Sounds like you may need a top side or dry side valve cleaner. Either find a BG service center or use something like this (see link below) and report back with your results.
http://www.gm-trucks.com/forums/index.php?/topic/170994-Intake-clean%2E--WOW%21/page__view__findpost__p__1598328
Sent from Off Driller Side
Could it be that you've braked too fast for the tranny to downshift and the torque converter is still locked?
That's possible but would just be another issue.
Once you completely let off throttle it is programmed to let go of the torque converter at any speed under 14mph for any gear other than 1st, and if in 1st the converter shouldn't be applied at any speed.
Doesnt really matter if I brake so fast or so hard it could even happen if i apply the brakes slightly.
MAF sensor is cleaned
Throttle is cleaned
Tuned vehicles with raised RPM dont have this issue
If you fill up the car with gas while the engine is running rpm will fall and the car would also cut off.
    tblt44
    tblt44
  • Who's Online   2 Members, 0 Anonymous, 548 Guests (See full list)
