Block plug question
Hey everybody. First post here. I just bought a 1998 Silverado with the 5.7 in it. I've got a coolant leak on the engine that is coming out of what looks like a small pipe plug in the block itself. The plug is about a 1/2" in diameter and takes a 5/16" square drive to get out. The plug is located on the passenger side of the block, just under the head, between the last two exhaust ports toward the back. It seems like this plug is simply cracked as the leak is coming from the center of the plug (a tiny jet of water), not from around the threads. My question is, any idea what this plug is for or what I should call it when I go buy a replacement? I don't know if it's an expansion plug or some sort, or a blank for a sensor or fitting? Any tips would be appreciated! Thanks! (I'll try to attach a picture of it. It's got gasket sealant all around it right now in a poor effort to minimize the leak until I can fix it.)
Thanks,
Wade
The left and right heads are both the same. The hole is used for a sending unit. So a sending unit would go into one head and the the other head gets the hole plugged.
    Brendan C
    Brendan C
  • Who's Online   0 Members, 0 Anonymous, 1,120 Guests (See full list)
