LED switch backs/ resistors
Chevysousa
Just need some fast info here...bought some switchbacks for my turn signals. and also purchased 4 resistors.... so per headlight i wire in 2 resistors correct? one for the top and one for the bottom right? so a total of 2 on each headlight .
also there are like 2 black and 2 blue wires just pick one of each im assuming so i can splice the resistor wires in.? blue power / black ground.?
THANKYOU :happysad:
I replaced my tail lights/ turn signal to LEDs and I had to put resistors per light bulb. Sine there was three wires I had to pick two and I guessed right. I tapped into the black and the green one and that got rid of my hyper flash. I hope this helps out.
  • 1 month later...
Hey all my first post here I have a 2015 Silverado LTZ doing a switchover to LEDs all around. I did my rear tails tonight using Morimoto XB switchbacks with 1 resistor for each bulb so 4 resistors total. I swear I read not to use the green wire to tap into for the resistor. I used the black and it looks grayish brown wire, I'm getting hyperflash though. So is it black and green? It started to rain so i couldn't try it tonight. I appreciate the help and love the forum.
Thanks
Thanks
It's black and green
Thanks Willie will I looked all over the internets for a of the right wires and here it is. I'll have to get up at the crack of dawn and fix my mistake. Thanks for the post and pic.
    Afennell19
    Afennell19
  • Who's Online   1 Member, 0 Anonymous, 671 Guests (See full list)
