Limp mode? 1996 GMC 3500
I have a 96 gmc 3500 cut away van with a problem no one can figure out, it goes into a limp mode is the best way I can describe it, it looses almost all power and it makes a whining sound from the exhaust. The more gas you give it the louder the noise, also when driving it when it goes into its fit you have to give it full throttle for it to go about 20 to 30 mph and the temp goes way up. It does not give a code when this happens and sometimes it will go hundreds of miles without doing it. Many of the times it does it all I have to do is shut it off and restart it and it will run fine but their has been times where that didn't work so I would let it sit over night and restart it and it would run fine. I put a fuel pressure gauge on it when it's doing it and it was fine, I have replaced the knock sensor and all O2 sensors, the map sensor, the distributor, the fuel injection block, intake gaskets, and ECM, when it was at the dealer to get the new ECM programmed they couldn't get it to do it so they had no idea. I even changed the tranny because at first I thought the noise was coming from the tranny but it wasn't. I'm at a loss for what more to replace. Please help.
seems like egr wide open.
1996 was very smart with that, the first year ever to be smart with it.
worth a check.
  • 2 months later...
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 411 Guests (See full list)
