97 Yukon almost dies when started.
1997 Yukon with a 5.7 Vortec has issues again. Just replaced fuel pump and filter. Couple weeks later and now every time I try to start it it hesitates and sounds like it just barely starts. Like it will stall out. Sometimes need a couple tries on the starter. Then really low rpms for a couple seconds. Then It runs as normal. When it used to start after 1-2 seconds of starter engagement it would fire right up. Seems to have a slight loss of power on hills and idles slightly rough, but not very noticeable. These issues were both present before the hard to start issue. From what I have read it could be 1)bad egr valve 2)leaking or stuck injectors, 3)bad fuel pressure regulator. I just went out and picked up a fuel pressure tester. So u will check pressure, turn off key and see if the pressure drops. This should tell me if injectors are leaking. I think? I heard to pull a vacuum line off the fuel pressure regulator and if it leaks gas while running or shut off then I know the regulater is bad. I think? Egr valve I just takeoff and check for proper operation. Watched a YouTube vid on that. Does all what I said sound like correct diagnostic procedure? Any help, advice, guidance is greatly appreciated. Last month I've done starter, fuel pump and filter and a u joint. Ran it for the last year with no problems whatsoever. Ran a week or two after fuel pum without starting issues. Tonight it started after 3 tries. But I'm 300 Kms from home and thinking of letting it run all night because I don't wanna get stranded so far from home. Please help.
Interesting, I am having minor issues with my 1997 Tahoe.
I had to replace the fuel pump this summer, and ever since it doesn't fire up instantly like it used to.
It will start, then die and I have to start it a 2nd time to get it running. Once it is running it is fine.
As an experiment, I tried turning the key and paused for a few seconds, which I think gets the pump running. Then I cranked it. It fired right up like it used to. Makes me think the fuel pump isn't starting up like it should be.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 901 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
