Auxiliary Switch Location
I have been all over this forum, and all over the internet for that matter, trying to find an answer to this questions without starting another topic, but I've had no luck.
A little background on what I'm trying to do. I need to add 3 auxiliary in the cab of my truck. One for the trailer winch solenoid, one for the backup/trailer work lights, and one for the off road lights I'm about to add to the front. Since my truck is an LTZ, there are really no free spaces on the dash to add anything. I'm thinking my best bet is to take out the garage door opener button in the overhead console and use the three holes up there for some small toggle switches. I need to cover the holes while making a face plate to mount the switches to.
My two questions for discussion are: 1. What thin, but strong, plastic material could I use to make a faceplate for the switches? 2. Without turning my dashboard into Swiss Cheese, does anyone have a better idea of where I could mount three switches in the cab?
I will only add this, from experience. Make sure they are visible, and use ILLUMINATED swicthes, so you do not leave one on and kill your battery. Small clearish tacklebox plastic is flexible and cuts easy enough to work with.. scuff and paint too. Good luck !
Can you mount your switches on the lower left side of the dash, on the left side of the steering wheel? They would be out of the way and not really noticeable unless they are illuminated.
If I had the LTZ dash, that's where I would mount the switches.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 418 Guests (See full list)
