Suspension/Ride Quality Improvement
jburch77
I have kings on my 2wd lt... Ride is the same as stock if not a little smoother, plus it levels the truck and handles 10x better on access roads
  • Replies 37
So I have heard not to combine leveling kits and bilstein 5100s just curious what if you just kept the 5100 on the lowest setting. Would it still be a problem? I have a modest level on mine of 1.5" I wouldn't mind another 1" or so to bring it perfectly level, and if I could dump the crappy ranchos in the process I feel like I could kill two birds with one stone????
Stop joking around with bilsteins and ranchos and cognitos, get a bajakits midtravel kit with kings. Problem solved
Well, I'm looking for increasing wheel travel but I want the stock appearance too.
If I ordered this can I just let it on 285/70R17? and I do no cutting, no welding, no increasing fenders coverage and no removing front bumper or cutting it?
I believe I can have both of them, the stock appearance and the best suspension system!
just get a set of camburg/mazzulla/readylift/cognito upper arms.. no need to replace the stock lower. same track width with increased travel due to the uniball..
This kit widens the front by 2.5" per side and eliminates the swaybar, if you want stock width they sell what they call a CHASE KIT, it just replaces the upper aarm, and replaces the front coils with kings.
I got the prerunner kit and had to replace the fenders to make room for the 35" tires because of all the increased travel, i also had the option of cutting like 3" of the stock front bumper but decided to buy their valance bumper and sell the stock one
mazzulla UCA says:
  • Install requires trimming the factory upper arm droop stop! I don't know what it means but I want the kit to be reversible to stock and it costs $999. they claim it gives the truck 8.5" wheel travel for the 4WD
CAMBURG didn't say anything about trimming! and didn't mention the wheel travel. it costs $699
readylift $800 and did not mention the wheel travel!
It is difficult to choose! I can't decide which one is the best for maximizing wheel travel while maintaining stock appearance and got reversible to stock feature too.
mazzulla UCA says:
the droop stop is just a tab to stop the factory arm from over extending and breaking the ball joint. you will have to remove this for all aftermarket arms. the travel is pretty much identical between them all. camburg is a bit cheaper because its a tubular arm instead of being boxed like the others. Personally id go with camburg because they are very reputable and I live down the street from them.
Hopefully I get the correct parts ;)
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
