gas tank leaking on incline...
First time here, glad i found you guys. I just bought a 2000 Suburban and filled it up for the first time. I parked it in my driveway which is on a incline of about 10 deg. with the front of the truck facing down(backed in my drivway). i smelled gas as soon as i got out of the truck or shortly after, but i thought it was a gas can i had outside. later i still smelled it and it was stronger near the truck, so i got a flashlight and wouldn't you know it gas is leaking at probally 1-2 drops per second from what looks like the gas tank itself. huge puddle of gas on the driveway. So then with my fingers crossed i started it up and turn it around to see if it will leak with the front of the truck facing up. so far it's not leaking.
Was it filled up too much gas?
I will take it back to the dealer tomorrow, but what do you think it is???
Sounds like it might have just been over filled.  I have a 99 Tahoe and It was over filled and was leaking out of the filler cap area when I was parked on a angle.  Definalty bring it back to the dealer.  They will find it.  Let us know what the verdict is.  And welcome to the site.
Later,
Brandon
Called the dealer this morning and told my salesman what happened. He immediately said "bring it in". So i brought it in and waited an hour or so to see what they find. About an hour and a half later i asked the service guy what they found, he said looks like someone changed the fuel pump/sending unit and either damaged the o-ring or the unit itself when they installed it. And they are going to install a new unit no charge. Which is only right but i did buy this truck as-is. So they did take care of me and I'm a happy customer.
And a very happy Suburban owner!!!! (so far...)
Thanks!
I was funny watching them trying to drain the full 33 gal. gas tank. They had to pull up another Suburban and siphon to it.
I have a 2001 suburban 25000 that I bought in January. Every time I fill er up, it leaks same as your saying.
Three trips to three different dealers and the problem is identified as a bad gasket where the neck enters the tank.  Also, the gauge is bad.
Dealer keeps it three days waiting for parts.  First time I filled it up since the repair, and the next morning there is that old familiar smell and spot on the driveway.  Inspection shows that the leak is occurring where the neck enters the tank still!!
Now, its back to the same lousy dealer to fix the thing they should have fixed right in the first place.
Best of luck to you, but I do not have much confidence in dealer to get things fixed right.
Maybe that's the dealer that originally did mine? ???  Your not in florida are you?
Good luck to ya, and hope they get it right this time.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
