2009 Silverado Window
Hello guys!
New on the forum here, I just sold my Jeep Wrangler and purchased a 2009 Silverado 5.3 with 60,000.
Anyways, the only problem with the truck is, the driver side panel for rolling down the windows works on every window EXCEPT the passenger front side. The passenger front side does roll down when you use the passenger front side window switch, but it does not work on the driver side control panel.
Any tips on where to start?
Thanks everyone!
Kevin
Sounds like the drivers side switch needs to be replaced.
Or maybe just the contact points cleaned.. it prolly has been used more than the rest.. my driver rear wouldn't work till I took it all apart and scraped it with a flat head screw driver?
AWESOME ill try that out before I buy a whole new unit. Thanks!
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,242 Guests (See full list)
