Oil results on the 91-S10 not so good...
BIG BLUE
This sample was the first I've sent since I bought this truck with 185,000 miles on it (now has 188,000+).  It's a 91 S-10 with the 4.3L(Z)code engine.  This thing has had an oil leak from day one and recently it's been showing signs of white sludge on the dipstick end.  So, I figured why not send off a sample just to see what the properties were.
Here is what Blackstone wrote in the summary: "BIG BLUE: Wear was poor in this sample, the metals from bearing inserts up near caution levels.  Iron, from steel parts, read quite high as well.  Silicon was high and may show abrasive dirt in the oil, but it could also come from coolant (inhibitors are silicone-based), which we suspect is getting into your oil.  Though we found no elemdnts common to ethylene glycol, nor any moisture, the oil's additives show moisture damage.  There are types of coolants that leave no elements in the oil we can detect.  Suggest having you cooling system pressure checked."  end quote.
Well, as you can see this engine with 188,000 miles is not the best on the block according to this report.  Listed below are the elements in ppm if anyone is interested.  First value is my sample, second is average (mine/avg)
Aluminum 16/6
Chromium 3/2
Iron 269/48
Copper 57/7
Lead 30/15
Tin 0/3
Moybedenum 23/47
Nickel 1/1
Manganese 2/1
Silver 0/0
Titanium 0/0
Vanadium 0/0
Boron 3/20
Silicon 21/10
Soduim 6/25
Calcium 1705/1140
Magnesium 44/470
Phosphorus 698/838
Zinc 765/992
Barium 0/10
Those are the values.  As you can see the ones that really stick out are the high Iron 269 vs 48 for normal, high copper 57 vs 7, high Lead 30 vs 15 and the high Silicon content of 21ppm vs 10ppm average.
I guess I didn't expect great results and I'm changing oil every 2000 miles at this point.  Previous owner must not have done much in the way of regular changes.  All I can do is keep an eye on the levels an hope it last through till spring when I get a new one.
Regards,
BIG BLUE
I use Blackstone labs, have been sending out for analysis on my trucks for over a year now.  They send you a sample kit and instructions.  Essentially, you pop the drain plug and take a sample mid-stream while the oil is draining, in the bottle they provide (about 8oz or so).  Test results are back in about 1 week and runs about 18 bucks.
I figure that's only about $6 a month to keep an eye on what's going on.  On my newer vehicles I send a sample about every other change.  Just sent a sample of the rear diffy fluid from my 97 Sub to see if there was any unusual wear properties in the R/P.   Results came back way better than normal for that one.
You can go to www.blackstone-labs.com or call them for a sample kit which is free.  Only costs to have the oil tested and runs less than $2 to mail it back to them.
Regards,
BIG BLUE
Did the oil have a "milk shake" like look to it?  IF so, that'd indicate a coolant/head gasket leak.
Although you seem to have quite a bit of cautionary data, I take these oil analysis's with a grain of salt.
I use Titan Labs to test my oil on my fleet of vehicles and I've questioned their findings twice.
1) With the Camaro, on the second oil change after I built the engine, they came back with a silicon count too high and it was something "critical" I needed to fix.  How could this be?  I just rebuilt the engine 2,500 miles before hand!
2) On the Silverado, on the third oil change, at 3,500 miles I submitted an oil sample from it.  It too came back with a Silicon count too high  and was something "critical" that I needed to fix.  How?  It's a brand new truck/truck enginen!  On top of which they said dirt had entered the sample.  How?  The bottle was inserted into the draining oil stream and then sealed.
CMNTMXR81,
Yeah, I agree with you mostly.  I don't take these samples as gospel and don't change anything drastically based on results.  I mostly do it for kicks and to keep a record of how the engine/tranny/diffy fluids are holding up during the intervals.
Funny story on the Silicon content, I once sent a sample in on my 97 Sub after doing some heavy duty towing and off-roading, I then changed the air filter with a K&N drop-in and the next results indicated "silicon values were much better than the previous sample, and we would suspect it will continue to decline."
With the S-10, I suspected coolant the first time I saw the dipstick and oil cap.  Thing is, I'm not losing any coolant in 2000 miles or so, but need to do a compression/pressure check anyway.  Oh well, for less than $20, it gives some good info and is one more record to show proper maintainence for resale ;)
Regards,
BIG BLUE
I've ran several tests using blackstone and never had the silicon to high problem. However, it took far longer than a week for them to have results. More like 3-4 weeks although that could be from the stinking mail going from seattle to colorado, its up hill ;)
Joel
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
