Battery Guage Question
I had my truck in the shop recently because of my bettery guage.  I was in 4 LO at night with the lights on and was having to use the brakes.  The lights got real dim and the engine died.  I had it towed to the shop and the said it had a code stored and they replaced the instrument panel cluster  ???   Anyway, I got it back and the guage is now to the left (negative side) of "14"  Before this it always stayed about half way between the 14 and the 19.
I didn't go through any water or anything I was just coming down a dirt hill and used 4 LO.
Just wanted to find out what other peoples guages read.  I took it back to the dealer but they said everything checks out o.k.
THanks for any input.
mine starts out a littel to the right of 14 but drops down to right at 14 after i drive for a while. I would check the volts with a meter with all acc. on and engine at 2k. make sure you have atleast 13.2 volts then.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,025 Guests (See full list)
