4l80E tcc issues?
have a 2001 chevy 2500hd 6.0L 4x4. shifts hard after trans warms up. goes away for a while if you turn off truck and restart.
well i got a tech 2 tool. and started looking at TCC stuff...
i was traveling steady 60mph in 4th gear (o/d) on flat and uphills/ downhills.
flat ground i noticed tcc duty would be all over from 30-98% ..along with slip rpm would be in the 50-100rpm. but would fluctate up to 200.... up hill duty would hit 98% and stay there, tcc slip would hit 250-350 or more.
4th gear kick down full throttle slip would hit nearly 900rpm.
i had 2 slip codes. after 20min of driving my tcc duty cycle went to 0% and stayed there?
i'm wondering if maybe the TCC or powervalve in the valve body are bad. or if the torque converter is bad.
i'm leaning more to the bad converter. but already have a full set of solenoids for the valve body also which i havent put in yet,.
any advice on what this may be? or what else i should look at on the tech 2?
it shift fine 1-2 2-3 3-4. and back no issues. but i do get very hard upshifts when this happens. like a shift kit.
pull the pan, easy without moving the cross member ( 2 front bolts are tough, but can do. ) then replace the shift solenoids and the Lock up . about 80 bucks should do it, OH and re use the factory tranny seal if its the rubber one with metal in it.. Good luck!
  • 1 month later...
I had the same issues on my 2000 2500 6l. All the tranny shops said to rebuild but I took the chance in a torque converter and it shifts like new again. My symptoms were hard shifts. I bought my torque converter from http://www.specriteconverters.comthose guys are very helpful and the torque converters are great. I paid my tranny shop $400 for the install. Some shops wanted $600-$750.
    Brendan C
    Brendan C
  • Who's Online   0 Members, 0 Anonymous, 972 Guests (See full list)
