Have a question about
BowtieFan24
You know the Chevy bowtie thats on the front grill part of the newer silverado's. How would i go about doing this and how do i get the bowtie off the front of the truck so it can be painted. Any helps would be great. Maybe a step by step detail on how to do it. I know alot of you guys have done it so i thought maybe i would give it a try. Is it a easy job im guessing it is cant be to hard. Thanks for the help guys.
BTW anybody remember me ya i know its been a while since i posted on here.
It's easy.  You just take off your bowtie and paint it.  For a  silverado you use a flathead screwdriver and remove the snaps holding down the plastic radiator shroud and reach behind the grille.  You should feel the tabs for the bowtie, just squeze and it will fall off, so make sure you have your other hand there to grab it.  From there I use some steel wool to rough it up, spay a few light coats of primer and smooth it with steel wool inbetween coats.  After that I do about 8 light coats of black paint (or whatever color you choose) and then a few coats of clear.  I've found that when using spray paint it is best to do a lot of light coats for a really nice finish and it seems to last a lot longer.  After that just let it cure for a few hours then stick it on.
You can see mine in my sig pic painted black.  For my silverado I had one that I painted red, still have it in my room as a matter of fact.
Hey thanks for the help Jon. Sounds easy enough and i'll let you know how it turns out i plan on doing it sometime this weekend maybe. I think im gonna paint it Red the truck is black but it has red pinstriping on it so the red should look pretty good.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 529 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
