Headlights not working..
Noticed my headlights didn't come on automatically when I started my truck.. Turned the switch and still nothing.. My fogs wouldn't even cut on... Hit the switch to high beam and they worked so I guess the low and fogs wasn't working.. After several attempts they finally came on.. What do u all think the is the prob.. If it was a sensor I should have still been able to turn them on with the switch.. But nothing from switch either.. Glad they are back working now but who knows how long... Any thoughts??
-StUdDaRd-
