Rocker plugs
I did google search on this and couldn't really find a good answer, but what anyone know what those black plastic plugs are on rocker panels are? Can you remove them to spray fluid flim in them for protection of the rockers?
Sent from my SM-G920P using Tapatalk
You can remove them, they just pop out with a screw driver. I hadto tske mine out to install my steps.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 757 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
