Tow Mirrors
Hey guys, so I have a 2002 Chevy Silverado 1500 with the basic power mirrors with Chrome caps, what I am wondering, if I purchase the power heated tow mirrors would they be a direct fit (like the power connection, and the mounting points)?
Thanks,
David
Yes IF you buy ones with the 99-02 specific wiring connector. The 03-07 ones have a different pin layout to accomidate the mirror signal in the upper trims. Easy to replace once you get the right ones, just pop off that triangular cover on the inside of the door, starting at the top. From there it's one connector and 3 10mm bolts.
Yea, I was looking at the Tow Mirrors on Amazon here, because the ones on LMC Trucks site are like $350.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,201 Guests (See full list)
