Your work has paid off...
pacodiablo
Pics will come next week.
It has not moved in four years and needs some work, I will get just what I need to get it running for now...
AutoZone Econocraft 75DT-E Battery - $35
LOCKWORKS CHROME IGNITION CYL. & KEYS COLUMN MOUNT  LC14280 - $10
STP Oil Filter S5 - $3
STP Air Filter SA326 - $4
and some tires (the ones on it are flat and dry rotted).
Right now it is sitting on a friend's farm, and since I have no room for it and the farm is right behind my house, it will stay there for the next 3 years.
Don't get too excited, if I don't find parking soon, I won't be able to take possesion of the truck.
After clearing some brush I discovered that the truck was actually a GMC, lol.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 1 Anonymous, 620 Guests (See full list)
