2016 Sierra Denali - Considering upgrading to 22" wheels
Mr.C.
I'm not crazy about the wheels on my new truck and I'm considering changing them for 22" wheels. It is a new truck with just a few hundred miles on it so I don't want to do anything that will screw something up like the sensors, or any of the other components that I have no idea about. I've seen a few wheel & tire sets on Alan's Wheels on ebay that I like, but they are not factory wheels and I'm just wondering if anyone has purchased any of these and what has been the outcome? Thanks!!
    contrabombarde
    contrabombarde
  • Who's Online   0 Members, 0 Anonymous, 829 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
