Will a lift void my warranty?
Vic15
I came across an article that I thought might be helpful to some.
"Although dealerships must show cause/effect that an aftermarket components contributed to the OE failure (part of the Magnuson-Moss Warranty Act of 1975), many service managers routinely deny warranty coverage if the vehicle has non-factory parts."
"The truck owner must then go over the service departments head and detail how the aftermarket part had no effect on the OE failure. Some dealerships know that most customers wont fight, even if the warranty denial is bogus: The service department makes more by charging the customer full pop compared to its discounted warranty-work reimbursement from the automaker."
Here is a link to the article.
http://www.fourwheeler.com/how-to/suspension-brakes/1411-pro-comps-2015-gm-12-ton-suspension-install-compatible-and-covered/
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,336 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
