Ram ProMaster
We currently have 2 express 2500 trucks for my plumbing business. On Friday I will be replacing one with a Ram 2500 ProMaster 136" WB high roof. At first I was hesitant to look at a Ram. After looking at them and doing some research I think they will be a good fit. I am hoping the front wheel drive will be better in the snow than the express. I liked the more room and many features and capabilities the ram offered. If things go well with this one I will look to replace the other express with the Ram as well.
My first choice would have been to go with a new Chevy. The problem with the Chevy is the extremely dated design. For roughly the same money it felt like the chevy was a typewriter and Ram (and Transit which I looked at as well) were both smartphones (stupid analogy I know). I was just tired with the same design, I wanted something fresh and with updates features. I plan on having the Ram for at least 10 years so I wanted something I would not get tired of.
The Chevy has been a workhorse for us and I feel like I am being disloyal, but at the end of the day I work hard for the money and I wanted the most bang for my buck. I hope that the Ram/Fiat will be a smart move and not one that I will regret. Time will tell.
My pickup is still a chevy and I don't see that changing, this was not an easy decision. I kinda feel mad at GM for not having a more modern competitive offering in this segment.
Well gm vs the other van is they are a frameless truck what do they call them a unibody. so i think if you get hit or back into something as we all seam to do with work trucks the fix probably will not be as easy as fixing a little sheet metal but have to be more because that is the frame so to speak.
GM deserves to loose it's customers to other MFGs we have been waiting for a savana 2500 for 22 weeks and all customer service will do is give you some assesory that they have and not a discount on the truck. and we still do not have it or is it even at the dealer yet. At this point i really feel like canceling everything and going to another brand weather it's frameless or not .
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,301 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
