Scanners
JonesNTN
I'm one.
Uniden
Bearcat 780xlt
I built a console for my s-10, complete with a kenwood coaxial speaker for audio, and two cupholders.  I have a glass mount antenna for it.  I would take a picture but my s-10 is back home in Baldwin county.
In my Silverado I just put it on top of my dash with the antenna lying across the dash.  I though about installing under the power outlets, but I didn't know if that panel could hold the weight.
Radio Shack scanners:
pro-74 for races
pro-94 handheld trunking
pro-51 for other 'stuff' that I won't mention
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
