Lift considerations, tire size ??
Looking to lift my 2015 Silverado LTZ 6.2L, I'm looking to run the 6" BDS lift, and run a 35" tire. However I don't know and no longer then this is possible. I have done some reading on here and it seems a body lift may be needed? Im unsure of the required backspacing to accommodate this size of a tire and have not settled on a rim! Any help or suggestions !?
Are you asking if a 35" tire will fit under a 6" BDS lift? I'm 99% sure the answer is yes.. There are numerous guys here running that set up. There are quite a few running a 4" lift with 35's
I want to avoid any trimming at all, would any be needed with a 4" or the 6"? Also how would I go about sizing my rims for proper backspacing looking to have the tires flush with my outer fender, or slightly sticking out if needed as I do plan to add flares in the future.
If that is about what your looking for then a stock offset is what your after. Those are 35/12.5r20 on a 6" BDS lift with zero trimming, zero rubbing.
Sent by a simpleton struggling to operate an iPhone.
Looks awesome, thanks a lot for the pictures, have you had any issues since lifting ? Any other modifications recommended once the truck is lifted ?
You can definitely run 35's with a 6" BDS lift. I ran them on my stock 20" wheels for a good while. The recommended backspace for the lift is 5.75" so if u plan on staying within those specs u will be limited on wheel selection.
I did add a 1.5" body lift but that was only to fit 20x12" wheels, if u stay with 9 or 10" wide there is no need for a body lift.
35's on 20x12s (-44 offset)d0a6f8db4f81dd35c38d80aca2a91729.jpge79f58f5e66189ab0cab4a596d55ea66.jpg
Half the tread of the tire to be exact. They stick out more than what I like but I've gotten used to them over the last few days. I've recieved numerous compliments since install.c6344c4c37bf0b341ac1be2bf144e37e.jpgcaaea233980c880912192153e8146774.jpg
That does look really really sharp! Only thing that would concern me is debris messing up the paint if you went playing off-road. But add me to the list of persons giving compliments on how it looks.
Did you put spacers in the rear to even out how much the wheels stick out?
Sent from my SM-G925V using Tapatalk
I have a question about leveling and lifting. I was looking to also improve my ride with a new suspension so I figured I would do a suspension lift and was looking at the bds 4 inch. Considering that the truck stock racks 2.5 inches. Does the 4 inch just lift both the front and rear by am equal 4? Or does the back rise by 2.5 and the front by 4? I am looking to increase my stance but I don't want it to be that much? Or would just getting a suspension set like icon and leveling the front to back make more sense ( as the shocks can go from 1 to 3 inches increase)?
Sent from my SM-N900V using Tapatalk
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
