Tie Down Toggles
Does anyone know if you can just buy the toggle wings anywhere (or something similar). I don't need the whole tie-down setup, but i'm looking for the heavy duty toggle wings that GM is using on these. I also don't want the cheap toggles that you can buy at any Home Depot.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
