Dual Auto Zone Control Manual Setting
I have a 2012 Sierra SLT with the auto dual zone control.
I do this to run it manually:
Turn it off, press power off button.
Press temperature control.
Set fan speed.
If AC comes on(and you don't want it) turn it off, press button that looks like a snow flake, press button for outside air or recirculate.
Before I park my truck when it's cold I do this, set the temp. to 75 degrees(or?), fan on high, turn off ignition.
When I remote start the truck it works and starts the electric seats.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
