Torque specs needed - Hood Springs
Good evening folks. New member here and this is my first post. I recently picked up a low mileage 2000 Silverado 2500. It needs very little as it has barely been driven (35K miles). I plan on getting a set of factory shop manuals, but haven't been able to as of yet. One of the few things needing attention are the hood springs. Unless the hood is all the way up, the springs are not able to hold the hood up. It doesn't slam down, but closes rapidly as soon you touch it.
Anyhow, I just picked up replacement spring assemblies from the dealer. If there is any way some can provide the bolt torque for these, it would be greatly appreciated.
Thanks in advance.
Spring assembly
Pics of the truck.
Helm Inc. prints the factory service manuals. DVD or hard copies, depends on the year of the vehicle.
Bolts for the hood spring are 18lb.ft.
Thank you!
I checked Helm and it says the service manuals are currently unavailable for model year 2000. I have searched the two different sections that seem to apply: Silverado and C/K Pickup/Suburban/Blazer. The latter returns a hit but says the above about being unavailable.
Any other places to check? I have found a few of the multi volume hard copies on ebay for between $200 and $300. That sound about normal?
Thanks,
Nick
Edit:
Update - I snagged the correct four volume set off of eBay for right around 150.
