Ball joint torque 2005 suburban
Hi, replacing busted boots on ball joints The ball joints are good, but I can't find consistent torque requirements for the ball joint stud nut. All I can find online is 74 lower and 37 upper. Any help would be appreciated. I'm talking about the ball joints that are mounted in the upper and lower control arms that go into the hub assembly. Haynes manual only references balljoint to lower control arm nuts at 52. I have no clue what that even is. It would seem that this information would be readily available out there...
