4L60E trans shifting
I got a Z-71 and the trans shifts firm between 1st and 2nd and semi-firm between 2nd and 3rd..
When I got my S-10 4.3L with the 4L60E it also shifted the same. I put the electronic mod. on it to firm up the shifts and it firmed up the 1st to 2nd even more and eventually started urching the gears it shifted so hard.
Finally (in the S-10) I noticed that when I put it in 1st on the column, that it would make the vehicle come to a stop an created a bad drag on the engine but in D or OD it was completely normal. This was worse with the trans. mod on than off.
This one (the Z-71) creates a slight slight drag when doing an idle take off in 1st but in D or OD is normal. It seems like its the nature of the beast and in my S-10 it was amplified by the electronic shift kit mod which also increased the trans. pressure when the mod was switched on.. which robs power from the engine due to the drag on the trans. pump.
Anyways.. if you all would just tell me how your 4L60E transmissions shift between gears.. than that would be great.
When I am at full throttle the 1st to 2nd softens up but is still firmer than 2nd to 3rd.
1st to 2nd in our '91 Shifts pretty firm. I doubt it was a 4L60E in '91 although I am not sure when they stopped the 700R4 and started the 4L60E.
They began using the 4l60E in 93.
My 91 has a valvebody and servo upgrade, it shifts pretty firm, not tire-chirping, but its will snap your neck if you aren't expecting it.
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 373 Guests (See full list)
