Redneck Sex Test
JonesNTN
Since most terms below are discussed in 8th grade sex ed.
Redneck Sex Test.
1. A menstrual cycle has three wheels.
True or False
2. Asphalt describes rectal problems.
True or False
3. Spread Eagle is an extinct bird.
True or False
4. Vagina is a medical term used to describe a Heart Attack.
True or False
5. The clitoris is a type of flower.
True or False
6. A G-string is part of a fiddle.
True or False
7. Semen is a term for sailors.
True or False
8. Anus is a Latin term for yearly.
True or False
9. Testicles are found on an Octopus.
True or False
10. A pubic hair is a wild rabbit.
True or False
11. KOTEX is a radio station in Houston.
True or False
12. Masturbate is used to catch large fish.
True or False
13. Coitus is a musical instrument.
True or False
14. Fetus is a character on Gunsmoke.
True or False
15. An umbilical cord is part of a parachute.
True or False
16. A condom is a large apartment complex.
True or False
17. An orgasm is a person who accompanies a church choir.
True or False
18. A diaphragm is a drawing in geometry.
True or False
19. A dildo is a variety of sweet pickle.
True or False
20. An erection is when Japanese people vote.
True or False
21. A lesbian is a person from the Middle East.
True or False
22. Sodomy is a special land of fast growing grass.
True or False
23. Pornography is the business of making records.
True or False
24. Genitals are people of non-Jewish origin.
True or False
25. Douche is the French word for "twelve."
True or False
:cheers:
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 642 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
