Uncomfortable sound
I have an '01 Silverado 1500 323ci engine Z71 and I have a rattling and scrapping noise coming from the front suspension and sometimes rear suspension as well. I'm not sure if it's drivetrain or not but I would like to know what it is to I can get it repaired. Thank you
Give us just a little more info to go on. Got video?
It sounds like it would be coming from the from axle or transfer case.
It only happens sometimes when I start driving in the morning. But after a little driving it goes away.
My 2001 sierra is doing the same thing. I have changed all of the idler and tensioner pulleys, belts and water pump and it did not fix it. Checked the wheel bearings and they seem fine. Its a 2WD, so no transfer case to make noises. If I figure it out, I will post the results, until then I am driving it. Only thing left to check that I can think of is the alternator to see if the bearings are going out.
I heard from a co-worker that it may be the u-joints
It was actually my muffler I believe, it's 15 years old
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
