Rear-end shimmy, panhard bars?
jup06
My 2015 Reg cab/6.5' bed bounces alot more than my 2008 reg cab/8' bed. I attribute the bounce to the shorter wheelbase and the stiff suspension. But I also notice a shimmy in the rear when hitting a bump while slightly turning.
I don't think a sway bar would do much for me in this case since the truck corners well but is there a way to cut that rear end left-right wiggle? Do they even make panhard bars for these trucks?
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,401 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
