Very NEWBIE Chevy Trailblazer
hitman1971
Hi I bought a 2003 LS Chevy trailblazer in March .. I love the truck ... I have been hearing this high pitch whine on speeds above 25mph ... I heard this could be a transfer case seal that may need to be replaced . Also when I start the struck up and I let it warm up ..I then go to apply gas and it seems like it wants to stall and hesitates alittle ...this seems to happen only when the truck is cold .Anyone have any suggestions . Everything is fully covered on the truck ... it only has 1500 miles on it . Any help would be appreciated .
Thanks
Chris
Bummer that your having problems with it so soon. I would take it in and see what the dealer has to say. I hate to do that my self but if it is a warranty thing then that is where I go. Good luck and keep us posted on what the cause is.
    Gkistler
    Gkistler
  • Who's Online   2 Members, 0 Anonymous, 892 Guests (See full list)
