Contacting Chris White / GTPPrix ?
Does anyone have a phone number or way of contacting Chris White (GTPPrix) @ White Auto and Media Services? I had a cluster sent to him for programming and haven't been able to reach him by email. I'm sure he's just very busy, but wondering if someone has a better way for contacting him?
If you read this Chris, do you mind PMing me your phone number?
  • 1 month later...
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 665 Guests (See full list)
