Gordon spins out Marlin at Dover
Elwood
By DICK BRINSTER, AP Sports Writer
June 1, 2003
DOVER, Del. (AP) -- Jeff Gordon had an eventful Sunday at Dover International Speedway, where he finished second to Ryan Newman.
But Gordon didn't receive the attention for his determined run at the end, he got it for his spinout of Sterling Marlin earlier in the race.
Gordon was apologetic. Marlin was furious.
``The 24 got up under us and turned us around again,'' said Marlin, who wound up 35th. ``That's twice in three races.
``It's getting kind of old. I don't know what's wrong with the 24, but we need to find out. You've got to give and take in this league, and he has done a lot of taking.''
Gordon called it a mistake, not an intentional act. He said his car might have hit the apron. He shot up toward the wall and caught the left rear of Marlin's Dodge.
``I'm sure he's mad, and I was mad when I got hit by him one time in Richmond,'' Gordon said. ``Hopefully, we'll get past it and move forward.
``He's not a guy I really talk to a lot and he doesn't talk to me a lot, so I guess we'll see each other on the race track.''
I was thinkihg the same thing as Marlin. It seems like Gordon has been doing this alot lately. I've never tried to keep it a secret that I am one of the biggest NON-Gordon fans, but it doesn't seem like him to be the cause of some many other cars spinning as he has been lately. I wonder what's up?
Yep Gorden hit him. I was there and I saw it. Not much on sportsmanship if you ask me. I am not a Marlin fan but he was racing stronger then Gorden.
    zibzer2
    zibzer2
  • Who's Online   3 Members, 1 Anonymous, 799 Guests (See full list)
