Infotainment Audio Thread
Thought I would create a single thread with all the important points on the 2014+ Infotainment system, especially where it concerns digital audio. I couldn't find the facts easily, mostly spread out among many threads, so I wanted to compile a single source here.
My findings are based off my 2015 Silverado MyLink BOSE system (IO6), which may or may not be affected by my LTZ trim level.
I will include others' findings as I'm aware of them. This page is intended to be a work in progress.
Digital Storage
  • 2014-2015 models with a center console came with an SD-card slot. 2016 models do not have this option.
  • As far as I can tell, USB and SD cards behave very similarly. Some people report being able to voice command a greater amount of songs on the USB drive, but I have not personally been able to recreate this. I generally prefer the SD card for it's capacity (up to 200GB as I write this), and it's stealthier appearance, which also prevents physical damage from a USB drive being accidentally hit or crushed, or simply being too long to fit in the center console USB ports with the lid shut.
  • Micro SD cards with a full-size ("standard") SD adapter work fine.
  • The file format I use is NTFS, formatted from a Windows 7 laptop, and it works. The owner's manual states FAT32, but I have not tried this.
  • Sometimes the USB stick or SD card doesn't load/isn't available right away. Wait a minute after starting up and remove/re-insert the card.
Digital Audio
  • Confirmed file formats that are working/supported are: MP3 (up to 320kbps)
  • Confirmed file formats that are NOT supported are: FLAC, ALAC
  • Files can be placed on the root of the card/drive, or in folders.
Digital Video
  • Confirmed file formats that are working/supported are: [To Be Determined]
  • Confirmed file formats that are NOT supported are: [To Be Determined]
Factory Add-Ons
  • The GM Accessories Kicker subwoofer (not the entire system upgrade) can be used with the BOSE system as long as Noise Reduction is not equipped. Noise reduction will compete with the subwoofer and attempt to cancel it out. I know noise reduction/cancellation was required equipment on the 6.2L motors for some really stupid reason, but on 5.3L it is optional. When I ordered my 2015 5.3L with BOSE, the dealership argued it was not compatible. I contacted Kicker directly and confirmed it was, and the dealership installed it on the left channel speaker output. I would think the factory BOSE subwoofer output would have been better, but I have not gone in and tried this. The Kicker subwoofer tends to be a bit overpowered at low volume, but at medium or high volume fills the soundstage very nicely and adds in the missing low end while fitting nicely under the smaller rear seat (as you may assume, a regular cab cannot use this add-on).
I have a 2016 and it has a extra USB port instead of a SD slot. Occasionally it does the same thing where you start the truck and it doesn't detect it until you unplug it and put back in but otherwise works great.
When you add the kicker sub does the factory sub remain functional?
And the noise reduction was found on the 6.2l not 6.0l. I dont think it was even a option on anything else.
Added your info, thanks for that.
Yes, the BOSE sub does remain operational, but since it's much smaller (I believe it's an 8") it has different dynamics and response than the 12" kicker optional box. I think they compliment each other.
I'd encourage anyone else with info or suggestions to post them up and I'll add them in. I'm certainly not the end-all of info on this system.
Actually if I remember right I believe its only a 6"
You're right. I don't know why I said 8"... all the BOSE systems have been 6" subs. Which I guess makes the 12" option even better; I only wish there was some adjustments on the amp it came with to bring the output down like 15%.
I don't suppose any mods here can enable long term editing for this post so I can keep it updated?
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 504 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
