Has anyone went from a procomp 6" lift to a 4"
I currently have a 6" procomp lift on my truck and for personal reason I want to go with a 4". What would I need to do to accomplish that?
Strut spacers and rear blocks. Any other major differences?
Pro Comp uses a different knuckle and spring seat collar on the front and a 3" block on the rear instead of a 5". The strut spacer is the same on the 4 and 6" kits. They achieve the 4" lift by using a spring seat that drops the height down for the 4" inch kit. Not sure if the knuckle difference will matter or not.
That's what I was thinking. Most of the part numbers are the same for the differential drop cross members. And the knuckle with the 6 in kit makes it so it looks like the upper and lower control arms are pretty even. So I theory I should be able to just get the blocks and strut spacer drop it. And get it aligned for the camber change.
    ballencd
    ballencd
  • Who's Online   0 Members, 0 Anonymous, 518 Guests (See full list)
