2006 2500hd 6.0 backfire misfire
driving to work,at stoplight ,dies..restart stars backfiring,bad miss.limp home.p0300 code try to start ,crank no start.put some maf cleaner starts dies.went got chevron 91 octane and lucas fuel injector cleaner.started ,bad misfire.i let it run a while,seems to be better.took it around block died at stop misfiring.barley got home.cleaned throttle body ,maf,any suggestions?still missing bad .rail pressure 55-60...please help
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 294 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
