Issues installing leveling kit
MonteLSx
I was wondering if anyone else had a similar issue or if it was just me being a bone head. I was installing my Procomp leveling kit in my 16 2500 and the passenger side went in fine. Driver side came out without an issue, but I could not for the life of me get the driver side key to load. I was using the Procomp unloading tool (see link below) and when tightening the nut to load the torsion bar it got so tight and I was not even close to being able to slide the retainer back in. I was thinking maybe the threads of the unloading tool need to be oiled/lubed to allow it to screw in easier. I didn't have an impact at the time since my buddy borrowed it and has still yet to return it, so I was just using a 1/2 ratchet. Per the instructions you are to do this before removing the upper shock bolts to install the shock spacers. Would taking the nuts off the upper shock mounts first help? The front end of the truck was raised off the ground but the wheels were still on.
Any suggestions/help would be greatly appreciated.
Thanks guys.
http://www.4wheelparts.com/Fabrication-Tools/Torsion-Key-Unloading-Tool.aspx?t_c=86&t_s=530&t_pt=7671&t_pn=EXP67965
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 483 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
