2014 Sierra SLE turn into Elevation Edition Picture Request
wnytruck
Hey Guys,
New to this forum. I am about to purchase a 2014 SLE Sierra DB Cab 4x4 v8. I am going to be vinyl wrapping the chrome on the vehicle to make my own "elevation edition". I already have the stock 20 inch wheels. Just wanted to know if anyone has done this and made there own elevation edition yet. I also want to know about tube drls. What people have done and used as far as replacement assemblys and such. If anyone has some pictures that would be great. I get good deals on used vehicles hence why I do not buy a new elevation edition.
Thank You!
