HELP RANDOM MISFIRE
I have a 1999 GMC Sierra 2500 2wd sle extended cab 6.0L
Mods
Msd street fire 8.5mm plug wires
New ac delco plugs gapped at 0.060
Cleaned throttle body
True dual straight pipe exhaust with cats
Mileage 261,xxx
My truck is a daily driver I have broken manifold bolts 3 on the driver side and 2 on the passenger side hasn't new spark plugs and wires and cleaned coil packs it gets spark and fuel but miss fires on SOME cold starts and only fires correctly when I hammer down on the throttle and run 1st gear to 5000 rpm at 45-50 mph and then will run normally otherwise it will miss and sputter with a lot of post detonation it will sometimes only run on the left side of the motor before I hammer it my buddy says that it's either fuel deliver or o2 sensor causing it to act weird it ran fine till 4 months ago then one day just started missing out of the blue
Help would be much appreciated
Replacement plugs for that from ACDelco are gapped .040 and are to not be adjusted. Any fuel pressure readings? Any DTC's (trouble codes)?
+1 on the plug gap. The AC Delco Iridium plugs are pre-gapped and not meant to be adjusted. They are .040" out of the box. You did install the correct plugs right? That system will only be happy with the original, factory spec platinum or the later, iridium plugs.
Check the fuel pressure regulator on the fuel rail. Check fuel pressure. Check and clean the IAC.
Post the DTC codes for us.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 788 Guests (See full list)
