Torsion key/bar question
So right now my 2003 silverado 1500 Z71 has the stock torsion keys (I think I bought it used 6 years ago) maxed and it isn't level. I was thinking of getting new keys but want to make sure the torsion arms aren't shot. The front end is close to the rear height but noticeably shorter between 1" and 2" shorter.
So will the stock keys maxed level the truck perfectly or will it still be short?
most times they will be short of level, just be warned the truck will ride like a pos when cranked level since it won't have any more downward travel left in the control arms. I would lower the rear if you have to get it level or buy a real lift kit.
    • For a limited time, Preferred Customers and online/catalog customers get a free magnetic level with their order of $100 or more when they use code LEVEL726 at checkout. Offer ends July 28, 2026.     Save up to 25% off retail as a Preferred Customer.  Sign up here.  https://www.amsoil.com/p/preferred-customer-registration-preg/?zo=521390   As always you can order here.  https://syntheticadvantage.com
    • Looking at cheap tires for this project '95 Blazer. I'm seeing all sorts of brands I don't recognize. 235/75/15 are the size I'm after.   "Dirt cheap" (<$100/each) Starfire Solarus (AS or AT) Rocky Mountain HT2  Mohave HT Westlake SU318 H/T Laufenn G FIT Entry Level AS (yes, Entry Level is the name of the brand!)   "Somewhat cheap" (<$150/each but >$100) Kumho Solus TA51a Ironman (Les Schwab) Cooper Discoverer RT AT Hankook Kinergy ST (H735) Milestar Patagonia H/T Toyo Extensa AS II   The only one that stands out is the Cooper Discoverer in looks and actual brand recognition for me. $120/each. The buyer for this truck will probably want a visual look of not a completely smooth car/highway tire and this one has slightly blockier tread.   Starfire is supposedly a sub-brand of Cooper. Mohave is a house brand of Discount Tire. The spelling bugs me, I've always known it as Mojave. Kumho, the name, still makes me giggle.   If I was selling it tomorrow, I'd probably go with anything in the Dirt Cheap category. But I may drive this around through the fall and my mind would be ruined knowing I'm rolling around on "Laufenn" or "Entry Level" tires, name alone.   In a world where *most* tires are now offshore-produced, is one low-buck tire much better than another?
    • Most vehicles have engine covers. The cooling fan’s are below the cover. That probably doesn’t help. I cleaned collector car engines. The rest not so much since the last one protested by missing for a few days drying out.
    • Point of clarification on this graph. It is the life of the FLUID not the Transmission being graphed. Compare to his comments below the graph. Get it to the top of the graph and you can kill one in an afternoon.
