2015 headlights
ohdoyle
So as we all know 2015 gm headlights suck.
Question is ,I was looking at the headlight parts for the 2016 headlights. Says led bulbs, and ballast and back plate with ballast. So on the sierra hd has anyone tried putting the 2016 bulbs and ballast in the 2015 as the assembly on the HDs is the same.
Link for 2016 headlight
http://www.canadagmparts.ca/auto-parts/2016/gmc/sierra-2500-hd/denali-trim/6-6l-v8-diesel-engine/electrical-cat/headlamp-components-scat
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 850 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
